- Joined
- Dec 10, 2007
- Messages
- 257
- Points
- 87
Hi
I was pootling along as one does when retired. Beep! and the engine control light comes on and the message Eng Ctrl Fault - Call garage.
Engine was and is fine and everything seems OK. Carried on home. Starts fine but the light is still lit and the message comes up intermittently.
My bug is pretty reliable so I haven't had much need to use the FiatEcuScan software recently. No problem, found the cable and thought that will give me the error..
'Connecting to ecu'
'No ecu response'
'Check your cable and serial port settings!'
Retried the cable
Checked the settings which were
K.Line/VAGCOM
Com4
Speed 9600
English
CSV Tab
I haven't changed anything since I last used it and the latency is as it was though I can't remember where to find it!
Tried the ABS switch on the cable - worked fine
Tried the Air Bag switch on the cable - worked fine
I don't believe it is the engine switch 1 on the cable as the error came up before it was connected
Can anyone advise?
Please don't tell me the engine ecu is duff as I had a similar problem with the ABS which couldn't be communicated with and required a replacement ecu
Last question: Can I still drive the Multipla
'Connecting to ecu'
'No ecu response'
Retried the cable
K.Line/VAGCOM
Com4
Speed 9600
English
CSV Tab
Can anyone advise?
