- Joined
- May 12, 2008
- Messages
- 5
- Points
- 3
That dreaded little red light has appeared on my 2001 JTD 110 ELX Multipla...
We've had the "Fly Boat" for nearly 9 months and she's just clocked 106,000. Only major problem so far was a driveshaft going AWOL but easily fixed.
The light and ENG. CTRL. FAULT message first appeared last week whilst pulling onto a dual-carriageway that was on a slight incline. It was busy so I gave it a little more "welly" than usual along the sliproad to get up to about 60 mph and merge into the flow of traffic. As I hit about 50 mph and was just about to shift into 4th gear (at what I estimate to be about 3,500-4,000 rpm) the alarm beeped and red engine management console light came on.
I panicked a bit and eventually pulled over to read the handbook to find out what this meant - the recommendation being "Go to garage." On the way home the light went off...
It has since happened 3 more times with the light eventually always going off. I assume this is because the ECU has detected a fault but sufficient time and/or mileage has taken place without it re-occuring? I noticed that twice the light went off after a short burst of speed - say hitting 3,000 rpm in 2nd gear to pull away a bit more swiftly than usual. I also noticed that the when the light is on the engine won't rev higher than just over 3,000 rpm which I assume is some sort of "Get You Home" safety mode.
So, the question is which bits of the engine management system do I start pulling off and testing/cleaning? I've removed the connection from the MAF (Mass/Air Flow) sensor but it didn't seem to make any difference. Should I remove and clean the EGR next? Which sensors are the most common culprits likely to cause this fault (before I move on to having the fault codes read and start worrying about expensive failing injectors)?
Also, I've scanned the internet and many threads on this forum to discover if it is possible to get a code reader for the pre-2004 JTD engine in my Multipla. I've seen in-depth discussions about standards, protocols and baud rates which don't scare me as I'm a software engineer but I haven't found anyone anywhere stating "I bought XXX code reader device and used YYY software to get the fault codes out my 2001 JTD 110 ECU." Any advice or am I stuck with taking it to a garage with suitable professional equipment and paying £30-35 per test session?
