Technical Electro-Valve TD100
whity
Budapest, Hungary
Hello,
So, Can somebody help me how can I test the Electro-Valve on the Injection pump?
It is maybe wrong but when i use the ignition looks like everything is good But the enginde is running i think something is wrong.
Thank you,
regards
If you put it ignition on (do not start the engine)...The valve has to make a tikking noise (if not the valve is broken).
The valve delays the injection. If the valve is broken the engine seems to run on three cylinders and smokes bleu from the exhaust. This part is very expensive (aprox. 230 euro)
