Hi All
I'm writing a few of my car's electrical niggles, in the hope that others have had them and can tell me if it's normal, or a problem to be solved (should be a laugh!).
1. Rain Sensor Sensitivity - even on Max Sensitivity the screen can get quite covered in rain before it gets wiped. Is there anything I can do? (can Fiat make it EVEN MORE sensitive?).
2. External Temperature Gauge - it sometimes doesnt change until the engine is switched off, then the ignition switched on, where it can jump a few degrees. However, it did go from 5.5C to 6.0C today whilst driving. It came up with -5C in July on the first day I bought it - my dealer said it was taking too long to alter its temperature, so they put a new sensor on it. I'm not too sure it has worked.
3. Drivers Side Electric Window - sometimes it can stop mid-motion on the one-touch. It doesnt then go back down, so its not the anti-obstruction sensor giving false signals. It can also stick sometimes too, meaning you need to press the switch several times to make it go up.
4. Deterrent LED - I've once seen it flashing whilst driving (all doors unlocked), and my dad says he's been out to the car and it hasn't been flashing. It didn't when I bought the car - they fixed it without putting a new LED in it, but have since replaced the door trim, hence a new LED is there.
I think thats all! Oh, and my car booms when Air-Recirc is on when on Face Vents and high fan speeds. Any ideas?
Thanks!
Stilo 1.6 Dynamic, 5dr, 2002, Crystal Green
Thanks!
