Ducato (Gen 3)  Electric window switch
Erc1958
Hi, I have recently bought a Laika motorhome on a 2001 Ducato chassis. The drivers side e window switch will not work when pressed to go down. If I keep pressing it and messing with it, it will eventually go down and will close no problem It is a double switch, the other one is for the passenger side, which is OK I have Googled to see if I can find the switch assembly with no luck.
Any help would be great, I live in Perth Western Aus, the m/home was imported from the UK in 2011. I could provide a pic of the switch assembly if required.
the switch is most likely standard FIAT,
ePER is the official parts Fiche;
http://eper.fiatforum.com/eper/navi...INT_MODE=0&EPER_CAT=SP&WINDOW_ID=1&GUI_LANG=3
EDIT = is it like this..??https://bartebben.com/parts/FIAT/du...ks-l-r-raam-zie.6552gp-655445-1303379650.html
( after 5 posts on FF, you can easily post pics, etc. )
Charlie
Thanks for the info I have emailed to the supplier to see if part is still available.
