Electric window..drivers side? QUICK RESPONSE NEEDED!!!
P
Paul R
Hi
I am currently removing the front two winows from the Bravo... I have removed the engine so there is no power!!!
I got a car battery and used two wires to power the electric window switch and hey hey the passenger window went up so i could put it half way!
Tried this with the drivers window and the switch was haveing none of it? the light on the switch lights up but the motor aint working!!! now i might have shorted the motor! but the problem i have is i need to raise the window back up half way!
Is there a manual over ride or can i remove it another way?
Many thanks
Paul R
The driver side is one touch so it may go through a relay ?
you can try fit the battery in place making sure all the +wires are not touching -earth and see if it works using the switch on the door
Trev
ps if this will not work remove the door card remove the window from the
motor etc and prop up with a stick/or a piece of wood
Re: Re:Electric window..drivers side? QUICK RESPONSE NEEDED!!!
Paul R
If You try this PLEASE REMOVE THE BATTERY if it works or not
Trev
Hi Trev
Many thanks for your reply...alas no luck! i am going to have to leave them down untill i fit her back up! (stripped for respray!)
I might have another go tomo!
Paul R
if you've got a couple of lengths of wire, power the motor directly.
I couldn't get to it? :( (not the terminals anyway)
Paul R
isn't there a plug to the motor?
a guy on our street has a marea and he reckoned that there was.
i'll ask him later if hes home.
C
2
805
K
G
6
634
M
L
1
745
Tommy K
T
