General  Electric door replacement from door winders
Jonathan7
Sheffield
Hi I’ve got a 2014 fiat farino van I’ve put some new doors on they have electric windows but dont work when plugged in but the electric mirrors do any suggestions?
Purely a guess, but does the signal from the switches have to be read by the BCM computer to tell the motors to operate.
It may be a case of getting the BCM to recognise them via a "proxi alignment" through diagnostic tool like MES or Snap On etc.
I know on many these days the motor only has two wires and no earth return, so the BCM tells the feed to reverse to provide up or down and also where top and bottom is.
I know if you have diagnostics and they recognise the window motors, when using the BCM program you can activate things like windows, lights etc. via the diagnostic tool.
