Technical EGR Valve for '58 1.9D Bravo 120
sambartle
Hoping someone might be able to shed some light on this for me.
I need to buy a new EGR Valve for a '58 plate 1.9D Bravo (120).. Looking on a few threads here people said that the part number is: 55215032 and thats available either from Fiat or from Vauxhall..
I've taken mine off and found that the solenoid is jammed so I'm going to replace it, and whilst the markings are pretty hard to read I think (im pretty sure) the part number on the current one is: 55204235.. which does seem to correspond to an EGR for a 1.9D 120 M-Jet but NOT a fiat one.. so.. I'm now a bit confused which is correct..
I'm not sure if this has been replaced in the past or not.. I cant remember it being done but i need to go back and see if i have any paperwork to confirm that.
Anyone know which I need for certain? (it seems to have been running fine with the 'wrong' one.. but Id rather buy the correct one if its not right.)
I found a copy of eper online and it appears that 55204235 is the correct part for at least my '58 120. (checked by VIN)
Probably worth checking if anyone else is buying one in future which is correct.
I used gsr car parts and input my reg, bought it, fitted it and had it sorted in 15 mins. Much better than trying to clean one, if you check gsr they have weekly voucher codes and I got mine for about 50-60 quid. It also said Vauxhall/saab on the box but as they use fiat engines I didn't worry and works perfectly.
