cumbriangeorge
- Joined
- May 5, 2020
- Messages
- 21
- Points
- 59
Whilst fiddling under the bonnet I became aware that the pipe which connects from the egr valve to the valve solenoid had become detached at the solenoid end (and had a split at the end). Although part of the solenoid valve (where two wires plug into the body) is visible I cannot see where the pipe from the egr valve should connect (without removing a lot of components). I have an inspection camera coming that hopefully will allow me to find the port where the pipe connects but if anyone can offer any advice that would be great. The engine runs great with the pipe disconnected and I dont know if the pipe was loose since taking ownership in 2019.
