can anyone tell me whats involved in replacing my ECU with one from a similar Marea
about 5 minutes...
undo the two 10mm nuts holding the plastic cover over the ecu in the passenger footwell.
undo the three 10mm nuts holding the ecu to the bracket, pull the ecu off of the bracket and then pop the retaining arm on the connector to release it.
refitting is reverse of removal.
you might find it easier to undo the connector and then remove the ecu but it depends how much loom you have to play with.
Ry![]()
make sure you get the codebox and red key from the donor car. fitting the codebox behind the dash is a 5 min job, once you can find it.
using the red key to teach the new codebox your blue keys is easy. i cba to type it all out, the procedure is in many previous threads if you search. it takes 1 min.[/QUOTE
i cba to type it all out, could you elaborate please Jug
ok, seen as you're a nice guy
to find the codebox you simply follow the wiring from the aerial around the ignition switch. it goes directly to a black plastic box that is behind the dash, up near the fusebox (slightly to the left or it). that box holds your key codes. it is paired with the ecu, so you must get a matching ecu and codebox.
the red key is paired to the codebox. it can be used to teach the codebox blue keys. that is the only purpose of the red key.
to teach a codebox some blue keys you must have the red key, but you msut also have 2 blue keys. both these blue keys need ot have different codes to each other.
so, lets imagine you get an ecu and codebox and red key.
fit the ecu, and the codebox.
take the red key to timpsons and ask them to make a copy using the new red key's code, but cut it using any of your original keys.
now you have a red key that works your codebox and also your locks.
finally teach the codebox your original blue keys using this procedure:
insert red key, turn to on position (mar i think its called?)
keycode light will illuminate then go out
remove red key
insert 1st blue key, turn to on positon
remove 1st blue key
insert 2nd blue key, turn to on positon
remove 2nd blue key
remove red key
job done, your original keys work with the new codebox and ecu.
they are, but you dont need to write a 2nd timeI thought the RFID chips in the keys for the immob are write
i've done it on several bravos and mk1 puntos and a cinq and it has not needed 5 times, only 1.you have to insert the red key and turn it on and off five times
they are, but you dont need to write a 2nd time![]()
So how do you teach you original keys the new code? That would be a 2nd write over which wont work.
you dont, you teach the car the original codes.
the red key is used to put the codebox into learning mode. then you can teach it any key code.
each codebox is paired with its ecu, so keeping your original codebox means it wont be able to work with the new ecu.If that was true then why bother swapping code boxes?
I think when i spoke to Tony, he said the code is written to the chip in the key. I could be wrong, but i think it is. I'll go read my old emails from him.
