ronnieronson Bring On The Trumpets! Joined Feb 6, 2007 Messages 1,464 Points 347 Location Hull Apr 11, 2008 #1 will i damage the ecu by just unplugging it? Or do i need to disconnect the battery 1st?
dave ****** Parked in the garage Written 10+ guides Joined Aug 10, 2003 Messages 125,210 Points 24,472 Location Essex/Suffolk border Apr 11, 2008 #2 shouldnt do. but it only take 5 secs to remove battery earth first so may as well be safe an do it
OP OP ronnieronson Bring On The Trumpets! Joined Feb 6, 2007 Messages 1,464 Points 347 Location Hull Apr 12, 2008 #3 dave said: shouldnt do. but it only take 5 secs to remove battery earth first so may as well be safe an do it Click to expand... aye - only asked, because I'd quite like to be able to lock and alarm my car while it's ecu-less...
R randomizered ' Parked in the garage Written a guide Joined Feb 16, 2005 Messages 5,983 Points 988 Apr 12, 2008 #4 unplug battery, remove ecu, connect battery Then you can lock the car and alram it Later unplug battery, refit ecu, connect battery See my other post about the light though. Kristian
OP OP ronnieronson Bring On The Trumpets! Joined Feb 6, 2007 Messages 1,464 Points 347 Location Hull Apr 12, 2008 #5 kritip said: unplug battery, remove ecu, connect battery Then you can lock the car and alram it Later unplug battery, refit ecu, connect battery See my other post about the light though. Kristian Click to expand... Settled for - unplug battery, lock doors manually, pray noone breaks in in the meantime
