Hi guys. I'm a bit stuck on this one so any advice would be appriciated. The missus has got a 51plate seicento 1.1 mpi. The ecu light comes on whenever the cooling fan kicks in.( i've managed to borrow a computer and the fault is engine coolant temp malfunction p0115)
It hasn't got a temp guage so i'm working blind here but the heaters get that hot you can't hold your hand in front of them.
I thought the problem would be the thermostat but i've changed that and no difference.
I then thought the rad was blocked because it was not getting hot, but after letting some coolant out of the bleed screw by the expansion tank you could feel it fill up with hot water.( i've spent half an hour bleeding the system so it can't be an air lock!)
So now i.m stuck. When i reset the fault the light stays off untill the engine obviously gets too hot.
