ECU Fault codes?? HGT Engine cutting out
S
S.B
I recently had problems with my Bravo HGT 2.0 155 cutting out while running/driving usually when slowing down or about to stop. Left it in a garage who have changed the battery as it was duff (expected as I was planning to change in soon). Now they ran diagnostics and 3 fault codes have appeared.
P0130
P0335
P1653
of which the last one cleared and the firt 2 remain. The engine is still cutting out.
"Does anyone know what the fault codes mean?? "
any ideas why the engine is cutting out?
They have suggested replacing the SPEED SENSOR which costs abot 25 quid... but that is not guaranteed to fix the problem!!
Any help much appreciated as am afraid the bills are going to run on :((... and the problem hasnt gone away...
Many thanks fellow users.
Could possibly be the lambda sensor on it's way out..
Mine was stalling at every possible moment when mine packed up.
Easy way to tell is to have the engine running, then unplug the lambda. You'll find it down on the right hand side of the exhaust (looking into engine bay), follow the lead up, and unplug the black plug.. (just to the right of the engine cover)
If there's no difference in engine tickover, sound etc, I'd say it's the lambda goosed.
Here are the following fault codes for you.
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0335 Crankshaft Position Sensor A Circuit Malfunction
For Sale: Fiat Bravo JTD HLX LINK
F
7K
F1-ANG
F
A
1
11K
Angelo
A
1
7K
Dark Lurker
P
15
12K
Dark Lurker
