Technical ECU codes
Technical ECU codes
Hi, I'm trying to make an ECU monitoring board (showing air/water temp, rpm, and other) but I need the codes to dialog with the ecu.
I know there are available the codes (example: send 10h code to the ECU to obtain the ECU ISO CODE), but I found only documentation about FIAT Coupè.
I need the Cinquecento Sporting ones.
May anybody help me, please?
Tom translated the ECU documentation. He should be able to give you a copy, and it should contain everything you need.
Keep me updated with this project, it is something i want - but don't have the time to attempt at the moment.
The original project was a digital instrumentation (sorry, I don't speek english well): I want give out the original RPM-meter and counter, and replace them with an LCD graphic display (where display also ECU monitoring) with a car computer embedded and controls on steering wheel.
Here are the two documents, English and the original Italien one.
Enjoy.
GeX
  • 16F protocol(italian).pdf
  • 16F Technical Information(english).pdf
So I presume you want to use a microcontroller to do this?
Its either that way...or the way the Coupe guys have done it...and the way (we) want to do it: use a PC with a TTL level converter on its serial port and talk to the ECU through that.
You could then get the PC to put the data on the LCD, as otherwise, it'd be lots of circuits...
Hello !
Where are technical info (dialog codes with ecu) of Fiat coupè ? :D
I look for hopelessly code dialog for my Marelli IAW 1AP .. :cry:
Bye. :worship:
Hello !
Where are technical info (dialog codes with ecu) of Fiat coup ? :D
Bye. :worship:
Hello,
Did you found the coupe ecu technical information?
I looking for it too.
Thanks.
