hello there, i have 2 niggly problems.
1. my rear windscreen water jet doesn't pump water to the screen.
2. i think i have the wrong wattage bulbs in the rear lights somewhere. what bulbs should i have?
silly me. its punto mk2. i try to fix things myself and usually do fine. the water jet worked until it ran dry and then when i topped it up, it never came back.
Running it dry may caused sludge to get drawn up from the bottom of the reservoir that then blocked up the pipe. You need to check that the jets themselves are clear (use a pin to poke them if necessary) or you may have to pull out the motors/ pipes from the reservoir itself to see if they're blocked.
If you're still having problems try asking for further help in the Punto section:
