Technical  Earth points
How about just adding your own ground point wire to the body at the vehicle rear and connecting to the existing ground wire?
Are you looking at lights with engine running? So voltage at normal running voltage.
This
If you can't find the current earth
Just add another
There to risk to adding extra earth's to the wiring as long as it all done correctly
Yes lights are on and indicators with engine running and earth applied but doeasnt stop the flickering , Continuity good @0.000ohms with or without extra earthing cable. So a bit of a puzzle.
Are the lights really flickering? Or just dimming slightly when indicators flashing?
