Have a problem with (now) both rear side lights not working on a 2007 X250 Lunar motorhome.
Initially I thought it was just the near side high level marker bulb blown, but then found the rear sidelight also not working.
Unfortunately I did try the bulbs on the offside and now have problems with both sides.
Bulbs, and connections all appear ok and have tried new bulbs but not buzzed back to the fuse box area yet due to rain stopping me, but suspect wiring and connetors are ok.
If I check volts with the bulb removed (either side) I see a good 12.5 volt, but when I put the bulb back in, it lights for a second and then it goes out and volts drop to Zero (this on both sides)
I know the side lights work through 'resetable' fuses so this is obviously tripping probably with over current ?. Bulbs out and power off and back on and seeing volts on the connector again.
Hate the thought of calling in a mobile techician to check as not many 'good ones' up here in North East Scotland.
I am struggling to find either a good description or circuit diagram for the 2007 Ducato which is not helping me fault find.
Can anyone point me in the right direction ?. Got good Volt/Amp meters and oscilloscope here for checks.
Thanks,
Martin, GM6VXB
Thanks,
Martin, GM6VXB
