Technical Ducato x250 2.3 multijet Towbar Connections
19cld79
Is anyone experienced in connecting up towbar electrics to a ducato van.
I've installed the towbar, got a relay to connect to, but how do you connect it to the van's electrics?
The reason i ask, it's that i seen that that you cant directly connect into the wiring harness, as it causes the dashboard lights to malfunction, due to the canbus system.
Any help would be appreciated.
:worship:
The best option is to use a plug and play harness that plugs into the connections of the rear light units and usually a connection to the fuse box. These are quite expensive and vehicle specific but a lot better than using scotch locks on a canbus system.
Attached is a pdf of harness instructions.
Mike
  • 19500516RC.pdf
Thanks for speedy replies, will look in to both options.
Hopefully get it sorted.
Thanks again
(y)
