Technical Ducato single pass seat
TEZ217
Hi All, I'm completely new to fiat's let alone ducato, I have just bought a 2006 ducato 2.0 diesel van/camper
I have been trying to locate a single passenger seat without much luck so far what I need to know is will a seat from a R reg Peugeot expert fit into mine ?
any info would be most helpful and any other idea's or help appreciated
thanks TEZ
You'll quite often find that another Ducato driver's seat will fit straight onto the passenger side as the vans were made LHD and RHD, so the drivers seat has mountings available on both sides. When I converted my Ducato to a campervan, I fitted a Sprinter driver's seat onto the passenger side. I had to make up strong steel brackets and swap the seatbelt anchor over from the old dual seat, but it can be done.
Bolt dimensions are the same both sides so you can put a drivers seat on the passenger side but as mentioned the seat belt anchor is on the wrong side I got an old box type drivers seat base and bolted the anchor to the side of that.
moodrater what box did you get? Was it easy to fix? I have a drivers seat available to me but no mounting box for it. Cheers!
