Technical  Ducato Natural Power instrument cluster / LCD
Silesia
Hello,
For my campervan build I'm planning to upgrade the rear suspension. I have two options:
adding pneumatic to the existing double leaf + spring suspension
or
replacing the entire original suspension with the factory pneumatic set.
I'd like to go for the second option for less weight, more comfort and possibilities (it would allow me also to lower the van, not only lift it). The only problem is the NQS instrument cluster compatible with the x250 Natural Power engine version. Other parts are more or less easily accessible because they are compatible with diesel engines. I know that pneumatic suspension was also an option on these Natural Power models.
I cannot find the NQS instrument cluster part number compatible with pneumatic suspension and Natural Power. Can someone please suggest where can I find part numbers not compatible with my VIN?
Or send me in private the VIN number of a known Natural Power with original pneumatic suspension, so I could check for the part numbers myself, please? ;)
I'd be very grateful :)
I tried to edit the original post, but cannot see how :D
As my technical English is far from perfect, that's how the first solution looks like on the van:
And that's how the second solution looks like on the van:
