Hello everybody, I have a 1998 Ducato motorhome with the 2.5td engine, I want to get the cambelt changed as I have no history, the mileage is only 35k but obviously age is an issue. My question is, does this engine need a water pump change at the same time, I won't be doing the work myself but I want to give my garage a heads up if necessary.
I totally agree with
@bugsymike comments . I replaced my own water pump , during a timing belt change last year on a 2.8 . My vehicle is 23 years old , with only a little more miles than yours . I have to admit this lead to a complete cooling system rebuild , but i'm not suggesting anything of the kind in this case .
Now , in pure basic form the 2.8 uses the same lower castings as the 2.5 , so i can confirm , the timing belt tensioner is fitted to the lower pump casting , which is also doubles as the right hand engine mount . As i would also advise replacing the tensioner at the same time , it adds very little to the actual job . Purchase a complete kit , and you should get both idler wheels , plus a new tensioner in the kit . I actually went a step further , by replacing the anti vibration plate , and dowel , as these were showing a reluctance to move , plus both the mounting and idler wheel bolts at the same time . I would further suggest replacing the four bolts that hold the pump in place on replacing . Mine where very reluctant to come out , and would have been put at huge risk of being over-stressed during re-torquing . It's just a personal preference , to prevent any further issues appearing should this pump require removal again , at any point .
Additional parts and bolts , can be sourced from Coastal motorhomes , in Hampshire , i think Ringwood .
One further note i would make is the antifreeze . Draining the system via the radiator plug , only half the coolant is released . There is a feed to the oilcooler direct from the themostat housing , but as this is level with the radiator top , this will not drain down . I have seen reference to a drain plug , but as yet not found such , so i just loosen a hose under the starter motor .
