Technical Ducato 230 , 2.8TDI clutch reassembly problem
rover17
Hello from France , sorry for my English ...
I first thank your forum for the help i found as i could not open de clutch carter , i made the special tool to take the fork axle away as seen here (y)
Now my problem :
I received a Valeo kit (from UK) but the release bearing is allready fixed in the clutch mecanism ! :eek:
I have seen a Spanish video where it is placed on the gearbox axle , fixed with the fork (on here axle again) and the operator seems to push the fork when the clutch carter is back on the engine :idea:
But here ?? Will i have to try to engage the fork and her axle after ???
How did you do ?
One more question wich side to place the clutch , there is a green color point on the big spring side , i beleive to place it to the gearbox side , right or wrong ?
I thank you very much for your help
Cordialement de France :)
Hello , i have just found the reply here :
kfzteile24.de/images/articles/full/006/624316500EA_VERB_FR.PDF
I just tried with the old release bearing and its works fine (y)
Very happy , but if someone can confirm wich side to put the clutch i would be very glad
Thank you :)
If you are referring to which round way to fit the clutch friction disc, they are usually marked on one side.
English: Engine side or Gearbox side
Italian: Lato Cambio (Gearbox side)
German: Getriebeseite (Gearbox side) or Motorseite (Engine side)
  • Clutch Plate Fitting.pdf
  • LUK 0025 de_FR.pdf
Hello Davren , thank you for your links
Unfortunately i have nothing like that written on the clutch friction disc (;)), only a green point of color
I just noticed a date , it was made 10 years ago ! New but old ...(Ebay)
Hello , i just understand the Spanish video (which i don't speak)
yout*be.c*m/watch?v=MwYh_dLIAqM
At 6mn15 he explains that in the wrong side the clutch friction disk cannot turn
So it is well the green point to gearbox
Bonne soirée (y)
