I've got the Ducato from 2014 and it usually takes one to three turns more than expected to start the engine.
In the end it starts just fine, but I would expect it to start quicker. Battery is new fine, glow plugs are fine, starter is fine.
I've connected Multiecuscan only to realize that pressure drops from ~300BAR when engine runs to just a couple BARs after I turn the engine off and then turn on the ignition for the OBD port to pick up new values. My hypothesis is that when I start the engine again it takes couple more cranks to build up the pressure, hence the prolonged cranking.
Question is, what shall be the high pressure fail fuel pressure after stopping the engine and for how long pressure shall hold?
In my case pressure rail drops immediately, would that be a symptom of leaky injector, damaged high pressure relief valve or anything else?
