Technical Dualogic going into neutral on the auto downshifts
Ok I noticed that. Is that the same type as the normal transmission oil? It says CS Speed fluid is SAE 75 W while the normal transmission fluid is SAE 75w-85. Any difference between the two?
CS Speed Fluid is not the same as the normal gearbox oil. Where did you find out it saying its SAE 75 W :confused:
I've yet to find an equivalent as seems impossible to find out exactly what it is, so I always use the OEM stuff purchased from a main dealer. Only £10 a Litre and only needs about 650ml from empty to full.
This is where I found it. Thing is I want to avoid fiat dealer like the plague = )
  • Car Dualogic OIl.pdf
