DTUK Pedalbox.
DTUK Pedalbox.
This all depends on your driving style.
If you a binary driver (full on/full off) then this box buys you nothing.
What you will see is that it gives lift / boost at middle throttle settings.
There is no problem with this other than it is a false feedback to the driver. You will get used to the increased thrust at middle settings and then feel deprived of power/progress at the wider/higher peddle/throttle values.
A possible bad/not so good side effect remapping the throttle is that one can think you are not driving the car hard (e.g. 50-60%) but are in fact at a much higher throttle angle (80-90%)
In the end then it is a driver's personal choice.
Where I would see this device being of real benefit is in mapping out the natural flat spots that occur on every car. i.e. engine poer/torque should ideally be linear to pedal position. 0 to 100% in calibrated increments. Sadly this is not the case in most cars. This device, if programmable could provide the linearity we desire without overplaying the effect.
Cheers for that s130, bit expensive I say, and when you look into the products almost all are the same,mind you I haven't looked that closely.
