At my MOT a couple of weeks ago i was shown that my rear wheels were hard to turn and told that my brakes must be binding probably because the wheel cylinders were seized through lack of use.Fair enough i thought i,ll check into it when it stops raining.
Today being fine and dry i jacked it up and found one wheel not too bad but the other quite hard to turn.So i removed the wheel and the locating pins to see if i could get the drum off to investigate but now the drum is rotating freely!!
So i replaced the locating pins and the drum is locked.Slack off pins drum rotates fine.As far as i can see all i am doing is moving the drum back a fraction of a millimeter.Could it be rust on the rear edge of the drum?Any ideas?
