- Joined
- Sep 2, 2007
- Messages
- 151
- Points
- 125
Hi there,
Uno 60, 'J' reg, 1992, 1108cc, 5 speed manual gearbox, single point injection, hydraulic clutch, CAT
I've got a slow but steady oil leak which I've traced to the gearbox area (smells of gearbox oil too). On closer examination the oil is seeping from around the driveshaft boot, even though the boot is held firmly in place with a metal clip and is in reasonable knick. The outer boot contains grease so any oil would appear to be dripping down from the inner driveshaft boot (?), which consists of a bush and seal.
I thought maybe just the seal needed replacing but after speaking to a Fiat dealer, I am a bit confused by the info I was given.
The dealer used my chassis number but came up with 2 alternatives:
"either a seal inside the diff or a bearing inside the boot".
However, after confirming the gearchange linkages are connecting rods not cables said that what I needed was a complete new boot. Apparently, this has a lip which acts as a seal. (?). I'm not sure if he was referring to an outer or inner boot on the driveshaft.
As I'm unsure of the exact set up on my car
(model details as above), can anyone else help?
Thanks,
Andy
Thanks,
Andy
