General Drivers door
Doblomutijet
Hi all,
I have a Doblo mutijet 2007 while driving I put down my door window which is electric when I decided to put it back up the top of the window came out of its track. I know the motor is fine so could the track be worn? has anyone had the same issue?
I can't help much but I had a similar problem a few years ago. I can't remember the detail but it was to do with the bit of plastic and the end of motor drive falling apart.
Can't remember how I fixed it at the time, but it was one of those moments where spares weren't to hand so it got fixed with bits that I modded from one of those oddments box (it come in handy one day....), I kept the broken bits and a couple of homemade tools to help with the job. See photo.
That's my offering!!
Ron
I had the same. Went with an almighty bang.
On mine it was the white plastic guide that pins into a small hole in the rear edge of the window. Not allowed to post URLs as I'm new on here but if you pm me I'll send you a couple of photos and the ebay link where I got mine from.
I did mine by removing the window surround rubber seal clip the new guide in place with the microscopic plastic pin, (fiddly) :bang: and then refitted the rubber seal guiding the clip into its slot. Easier if there are 2 of you as you need to guide the window up and down and of course if you press the button too long it wants to go all the way:cry:
