General  Drivebelt Slipping
br4duk
Greater Manchester
Making a screaming noise Im i right thinking u gotta move ythe alternator adjustment bolt and lift the alterntor round or have u gotta go tho the right underside??
BRAD
How hard is it im no mechanic but not bad?
1299cc 70SX Uno Mk1
KERR NELSON HT Set
Champion Sparks
Large Custom 4.5 Inch s8 through backbox
Stock everything else so far
are you replacing the belt or just adjusting it? if its adjust its an easy loosen the bolt of and adjust,although you may need a lever to get proper tension.if its a belt change then if its like the cinq you need to get underneath and maybe take the wheel of for access,but its not a hard job
The Fiat Cinquecento
Fun While It Runs
Nice 1 Custard needs adjusting i think, will do it at weekend
BRAD
1299cc 70SX Uno Mk1
KERR NELSON HT Set
Champion Sparks
Hei.
It may be worn out. If tightening doesn't help, or it is impossible to tighten it more, you should get a new one. A new one is anyway a good idea to keep in the spare wheel arch in the trunk. The reason it whines when cold is because the alternator charges more during startup to boost the battery. When it whines it doesn't charge properly, and you'll soon have problems starting. Well, maybe not soon, but in a while. So if it snaps, the battery won't be charged at all, just delivering power, and it won't take much time before the headlights drains it all.
Morten.
Abarth alloys. Inter Alloy lowering. Phoenix Gold & Kenwood audio. Abarth steering wheel. Insane Dalmatian door and seat refurnishing
Projects: K&N induction kit, racing seats, exhaust, window tinting.
Problems starting like i got
1299cc 70SX Uno Mk1
KERR NELSON HT Set
Champion Sparks
Gonna try and tighten it at weekend
1299cc 70SX Uno Mk1
KERR NELSON HT Set
Champion Sparks
