General Doors open warning
KimG
S. Lincs
I have read the sticky thread, copied & pasted below
"Fault : Door open warning light on
Cause : Sliding door contacts
Cure : Plastic plunger in centre of contacts not fully depressed
when door closed. Stick tiny piece of plastic to plunger to pack it
out to ensure correct operation of ajar warning light."
Can anyone tell what sort of size the plastic should be please & what have people used for this?
TIA
size that fits:), look around the house and see what you can use! I have used a small screw, double sided tape, tiny (3-5mm) piece of plastic stuck on....anything that will basically push the plunger in a little bit more(y)
