Technical  Door trim removal
widemouthfrog
semper in merda
Deepest darkest Wiltshire
There's a rattle in my drivers door that i'm trying to get sorted. I've removed the large plastic trim (the one with the hand grab) from the inside of the door, now I'm trying to get the cloth-covered panel off.
I can see some red-topped fir tree clips dotted around when I peer in through the hole where the plastic moulding was. Are they the only things holding the cloth-covered panel on? If so, it looks as though I just need to give the thing a good pull. I bet the fir trees go west when I do it though.
Any advice very gratefully received.
Yes the clips are on the panel, I use a wide screwdriver or better still a thin wide piece of metal near clips and gently lever apart, if your lucky you may not need any new ones but they can break easily.
