Styling Door trim fasteners.
Albert Alfvag
Uppsala
Hello everyone.
I'll keep it short.
I have my panda 4x4, but the doors are taken from a regular fwd panda, which means that they don't have the plastic knobs on the side where the black side trim panell is attached.
I tried to attach the trim with double sided adhesive foam tape, but it doesn't seem to be holding up. Does anybody know if, and where, I can buy those plastic thingies so I can attach them myself to the doors?
I tried looking at ebay and found these: http://www.ebay.com/itm/10X-FIAT-PA...lips-9-10mm-/221893398436?hash=item33a9e08fa4 but I'm not sure if those are the correct ones.
Alternatively, can someone recommend some kick-ass powerful double sided adhesive foam tape that can hold the trim in place for sure?
Thanks. :)
//Albert
those clips are not the correct one.
I will check as i had bag of them somewhere.
If you prefer not to drill holes in your good door have a read about 3M VHB tape- not cheap but worth the monney.
Ah thanks alot! I had a read about the vhb tape. The stuff seems increadible so I promptly ordered some from ebay. :D
Make sure both surfaces are threated prior to adhesion, allow 12-24 h to cure. Ambient temperature does make massive differnce to cure time.
Cool! Maybe I'll get some anyway, seems like it would be good to have around if the need arose for it. :)
I will get some Tiger seal for my new rear spoiler???
Sent from my iPhone using FIAT Forum
