hi here is how i did it.first you take the plastic cover from speaker then you unscrew the speaker .the speaker has a connector ,you have to take it out.next you unscrew the plastic door cover, it has two screws behind 2 plastic round things.next the door handle 2 little screws ,you can see them if you look under the door handle after that the little thing that shows you when the door is closed or open .with that thing up you have to pull that red thing out a little bit ,then you can pull it out .next the door cover .you put your hand in the speaker hole and pull slowly along the cover,careful it breaks easy.now you unscrew the screw that is on the carbody and then the 2 screws that is behind that rubber on the door then you take it out through the speaker hole .then you put everything back together ,dont forget something .i hope that helps. sorry for my english
