General  Door lock nuts
Markjb
Herts
I’ve Googled as much as I can and hope someone can help.
I fitted a metal door plate to the drivers door and I’ve lost one of the nuts (there are three of them).
I’m trying to find a replacement but can’t find them anywhere - can anyone help?
I left the one accessible via the grommet to save me having to strip the door down again!
Thanks in advance
Is anything special about the nuts? Have you tried a search on Ebay for nuts of the correct diameter? Probably 5mm or 6mm, so M5 or M6. Standard M6 thread pitch is 1.0mm, while M5 has an 0.80mm pitch.
Thanks for the reply. That’s the problem, I don’t know what the size is now I’ve put the door back together and wondered if anyone had access to a parts list.
I used a 10mm socket to take off / put back on - that’s all I know.
Would that fit with either a M5 or M6 nut do you know?
Thanks again
It looks like it could be M6 - thanks for your help
I should have mentioned that M6 nuts take a 10mm spanner. If you search on eBay for M6 nuts, you should be offered a large selection, and be able to purchase small quantities.
