Technical  Door lock issues
Macca238
Wales
Hello everyone, I have a 2008 Doblo 1.9 with a few problems. I'm currently tackling it's central locking problem.
The doors wont stay locked, door lock bounce back open.
According to Multiecuscan the rear sliding doors are showing as open when closed.
I'm looking for the door closed switch and also a possible pinout for the sliding door connects.
thanks for the help
Dave
Hello,
There are a couple of threads on the forum about the connector problem on that door.
That's one of them:
You can see the problematic contact on the photo. Of course cleaning and greasing is a must. I've seen another one explaining where and what to put to ensure better contact.
I feel your pain. I tried packing the contacts out, but I'm still having the issue. The door isn't actually open, but the incessant flashing on the display is a little annoying
Thanks for the advice it turned out to be a problem with the little black switch not being pushed on the N/S.
Im a little confused as why Multiecuscan see both sliding doors as either both open or both closed. Is this correct, but at least the doors lock.
Does anyone know whats behind this cover i found on the N/S pillar and what its for?
Ta again
It's a system to prevent opening the door when the fuel door / cap is open.
I'll find you a proper thread and link here.
