I think I am having lambda sensor problems based on the symptoms below, I just wondered, before shelling out for replacement sensors, whether I am thinking along the right lines!
Juddering/Complete lack of power: Started at just 3000 revs but developed to randomly to pretty much any time there is no response from the accelerator and the car feels spluttery to the point that it could cut out at any second and then will jerk back into action and will run fine again.
Rough idling: sitting in traffic or at lights it sounds like she is going to cut out/die for a few seconds, then sounds fine then sounds dodgy again (repeat).
Engine Management Light: it’s on and reader is showing emissions problem when the codes were read it indicated a lambda error.
One of the sensors seems to have had the wire cut and re-attached with electricians tape – I have been told this is not the best as the wires are silver and don’t fix back together as well as a copper wire would and this could be causing problems.
Am I right in saying there are two sensors pre and post CAT – do both require replacing at the same time?
I have read that it’s best to get OEM sensors (at a cost of around £45 plus VAT) does this price sound about right. Or does anyone know of anywhere to get them cheaper?
If I don’t get OEM and replace with cheaper ones for half the price they are likely to need replaced more – is this right? How long would I expect to get out of OEM ones?
Thanks in advance
Hutchie
Thanks in advance
Hutchie
