Technical  Doblo whistles
zykor
Hi every one,
I'm having some problems with noise (whistles) when i'm driving at 120kmh or more, any one had the same probs? Any idea about how to resolve it ?
tks
Joaquim
zykor said:
Hi every one,
tks
Joaquim
Check the back door sealing strip. Shut the doors.
If you're foots flat on the floor, and your going quite fast then the whistling is probably the turbo working hard (if you car has one and the whistling is not that loud)
I get a whistling noise at around 80+MPH but it doesn't sound like wind, and only when my foots flat out :)
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA!!! :D :D :D :D
Ozzie, driving in your dreams doesn't count....... We all know you've never made it into top gear yet :p :p
zykor said:
Hi every one,
tks
Joaquim
Yeah, but what tune does it whistle?
Took me ages to find a whistling noise, but tracked it down to poor fit of door mirror plastic trims. There was a gap, (only on one side of my Dobbin), where the coloured insert fits into the black surround. I filled it with clear "instant gasket", wiping away any excess, and that did the trick.....Try a length of tape as a temporary measure to see if that is the problem.
My Doblo was whistling when approachimg 70mph. I took it to my local Fiat dealer who quickly realised it was a poorly fitted windscreen.
The windscreen was carefully removed and refitted professionally.
Problem solved immediately :)
