General  doblo rear washer
griffo43
when i press arm forward rear washers dont work but front ones do how can i check the fault
Can you hear the pump?
If you can, it's either a blockage or your back door is full of water because the pipe has split / come off
No pump? Check fuses first, then wiring (hot wire the pump to see if it works. if it works, it's wiring)
