Technical  Doblo Problems
jonkemper
Hi i have a 02 1.9jtd Doblo Cargo,
It has a few problems that i cant find any answers on howto fix them.
1. The Speedo is intermittant, it will work then suddenly stop, im having to use the speed indicator on my satnav atm. started doing this after the clutch was changed, so suspect a loose cable but cant find it.
2. The Cab Blower has stopped working on 1 and 2 , it works fine on 3 and 4 though. Not sure if it uses a resistor or is a multi speed motor. so any advice would be welcomed.
There is a small earth lead fastned near the mounting bracket , if this is left of the speedo won't work
(i have done it):bang:
hi,
The demister does use a resistor, located in the top of the passenger footwell. Just one screw holds it in.
