Technical  doblo cutting out
stevefl
help my doblo idles fine drives fine on full throtle mid range starts to judder then it cuts out then starts straight away then drives ok then dose it again it is worse when damp done air flow flap egr valve checked fuses relays hope some one can help:bang:
hi it is a 2001 1.9 d non turbo never had the engine light on but today when it was cutting out the key code light stayed on it seemed to run better thanks steve
hi thanks for the reply can you tell me where the exhaust filter is on the car thanks steve
Well if its fitted it will be just down from the front pipe and look a bit like a cat
1.9D very prone to diesel pump problems and expensive to fix. I think I've been through every problem inc the ECU playing up but thanks to a great diesel expert it runs like a watch now. Fingers crossed.
hi cutting out gets worse when it is raining + misfire thanks steve
