Technical  Doblo Cargo rear leaf spring
Monty...!!!
stoke on trent
Hi guys I have 1.9jtd Doblo Cargo 2002 I need a rear spring my local breaker as a 2006 model high roof type doblo anyone no if the rear leaf springs are the same thanks in advance.
Monty
Monty
Anyone no if a 2006 rear leaf spring is the same as a 2002 don't want go to the trouble of removing it to find out it will not fit
Used springs are a bad idea.
Always replace both together as a pair, preferably new. Both your springs are the same age with the same wear. If one has broken, it is likely the other will go too, soon.
The rear springs can be different compression rates for different load ratings. The high-roof is likely to have a higher load capacity than a standard van, so unless you can be certain that the donor is the same as yours, you should not use them. Don't think you can "upgrade", as the springs may not be the only thing necessary to increase the load capacity.
Isn't the 2006 a different model than yours? Some listings show a change 2005, so probably no good at all.
Look in the traders section, contact Sturgess and Partsworld, with your full VIN number and get some quotes.
Its an old van and not worth a new spring was just trying to find if it was the same part number anyway have done it now and it fitted and sitting level and drives fine thanks for the reply
