Technical Doblo ABS sensor
bogush75
Hi guys, is there any difference between european abs sensors and UK ones?
I can buy them on continent for £10 each. Cheapest in UK I found £45 each.
Tom
  • Like
Reactions: TD5
Use the ePER link on this website to get the Fiat Part Number. Then check with your intended supplier EU supplier that they are supplying the equivalent/same part.
In ePER you can also check out the P/N if you switch from RHD to LHD. This could be a difference due to lead length.
  • Like
Reactions: TD5
Cant find the abs loom in epir under breaks or electrical 07 plate 1.9 multijet:cry:
