General Doblo 1.3 Cargo 2011
Isdahl87
Hi, is it possible to install original front fog lamps? I've checked that there are connectors inside the front bumper who is the same as those who are placed on factory fog lamps. Is there a wiring harness ready for this, only needed is a relay and original switch on console, or someone has another tip/idea?
I installed fogs on my punto last year similar setup with wiring already in place, I needed the lights the switch on the dash and some plastic bumper trims to allow the fog lights to be fitted but found with the wiring already in place so was the required relays etc so it was very much plug and play
I would suggest if you have the facilities hooking up to a laptop and activating the front fog light circuit via software this will allow you to check the wiring with a multimeter for live and check the dash light works
