Hi all,
I own a 1987 (88?) X1/9 and have had it in my possession for the last 10 years.
Very early on I switched the Marelli S178MK(?) distributor (just looked it up in the Marelli catalog...) for a SE100EX(?) taken from a Uno 60.
Now some ten years after I'm having second thoughts about the ignition advance curve. The issue is that the original distributor doesn't have vacuum advance, so the centrifugal mechanism is able to turn some 25-30º on it's own.
Now the SE100EX (breakerless) originally had vacuum advance which I blocked using the arm from the S178, but from what I've been able to find out, it's only able to turn 16º on the centrifugal advance.
The bottom line is that I've been running (and lots of other people who run the same distributor) a seriously weird ignition advance curve. What's even worse is that the car runs pretty well, so I don't want to "fix it" without having a very clear idea of what I'm doing.
Any thoughts / ideas?
