Technical Disconnecting the cigarette lighter
WinterRose
I am attempting to replace the fan heater speed control on my Fiat Punto Active 2004, and have removed all the relevant screws to remove the centre console, but I cannot disconnect the cigarette lighter. I have read the Guides related to this, which state that it simply pulls out but it does not.
Any ideas why?
As an alternative if I were to cut the wires as close as possible, would I be able to reattach them later?
Any ideas why?
The wires do pull out but you have to do it in a particular way
https://www.fiatforum.com/punto-mk2...ole-removal-bulb-replacement-3.html?p=4015905
You just get a good grip and pull it out. (or at least i do). It works for me.
Thanks for the reply, but that will enable the removal of the bulb. I am trying to disconnect the white block further back.
You simply need to just disconnect that white plug
A little jiggling and that whole fasica will come off without issue
Those white plugs on a first time removal cant be a little tight - press and wiggle
it will come off- access aint great but its totally do-able
Ziggy
Thanks Ziggy122 for your reply, unfortunately I am impatient and I cut the wires. There is a catch on the driver's side that you have to push in, in order to release the white block. Also I can repair the damage done with a little extra wire land solder so not the end of the world.
I have taken some photos so that other can see where the catch is.
Thank you all for your replies, it is much appreciated. :)
