Disabling EGR valve on MJET 8V
volvo_saint
Lija
I would like to disable the EGR valve on my 2008 MJet 8Valve engine.
Is there a kit available?
Or step by step instructions?
Should I expect fault codes to be thrown up by the ECU?
the vauxhall 1.9 and 1.3 models have blanking plates available same engine so could fit
try courtney motor sport
I have fitted the blanking plate to dis-able the EGR valve about 2 weeks ago.
So far 2 beneficial effects:
1) The flat spot at 1800rpm is no longer there
2) When I accelerate hard there is no longer huge black smoke clouds being ejected from my exhaust (my car has the DPF unit removed)
Later on I will check the ECU for fault codes.
