General Digital clock
jamx2
United Kingdom.
I have just noticed that the Digital clock above my rear view mirror has completely stopped working, there is no display at all just black screen? Could this be a blown fuse or something more than that
It is an 'R' reg not sure if that is mark one or not. If it is the bulb how do I remove the clock and replace the bulb without damaging the interior?
I have recently changed the bulb in my P reg.
Fairly simple first take the glass bit off the lights then the plastic panel around the light switches (small flat screwdriver should do it),you now have access to 4 (i think) screws just remove them and the whole overhead console is released giving access to the clock.
Hope this helps.
You can also check out a previous threads as well. It was mentioned not long ago(y)
The torx screws as said above can be removed by the right size straighthead screwdriver but I now keep a torx driver T20 in the tool kit as also fits Idle control value as well
Thanks,
Which fuse would be for the clock and what else would run off the fuse, I do not want to start pulling things apart if it was simply a blown fuse
Ian described the process on this perfectly, I have now changed the bulb and clock working again
Excellent as Fiat told me on the phone it was a sealed unit
