Technical clock/radio fuse
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
normd
Hi there, the clock and radio in my '97 2.0 S have stopped working but I can't find the fuse? I assume it's the same one for both? Doesn't appear to be in the main fusebox under the bonnet - can anyone advise please? thanks in advance.
There is a fuse box in the car.....below the drivers wheel if I recall correctly (I recently exchanged my trusty old mk1 for a mk2 so don't have the manuals to refer too!).
Your manual should point you in the right direction if you have it?
In my mk 1 EL, the fusebox is behind the lower glovebox. I know this because the previous owner smashed said glove box to get to it!!!!
JohnDoyle you are The Man!:worship: Thank you, found the dud fuse (y), replaced it with a six inch nail :eek: (don't have a manual so don't know otherwise:devil:) and now have sounds and time :D
