Re: Re: Re: Re: Re: Re: Re: Difference between Mk1 and Mk2?
Make sure you get the red key, and check it fits the car!
Or buy one with no red key but make sure you get a good discount!
Not having a red key in practice is no big deal as it only allows new blue keys to be programmed into the immobiliser.
You will only need to do this in 2 sets of circumstances
1) You want to add a new key, supplied by Fiat. The answer is not to do this. Get your current blue key cloned at a local locksmith. Cheaper and more convenient.
2) The immobiliser has forgotten its key list. There are no substantiated reports of this, but plenty of rumours. (My mate knows someone who heard that his mate had this happen etc.) You can only conclude that it doesn't happen under any set of normal circumstances. If it does happpen, its most likely a problem in the immobiliser anyway and will require a new set of electronics, door locks etc, and so you'll end up with a new red key, even if you had the red key originally.
Hope thats of some help/comfort!
Nick
