gengis
Hi Troops,
Found some diesel on the drive the other day, just thought I'd overfilled. But it is a constant small leak, had a look and it seems to be coming from the top of the tank.
Is this a common problem? and if it is what's failing? the pipe fittings or the pump/sender unit. Would it just require a new "O" ring for the pump/sender and is a "o" ring available?
Has anyone came across this before?
Fiorino 1.3 Multijet
